Go Back   NewTek Discussions > LightWave 3D User Community > LW v9.6 Gallery
Reply
Thread Tools Display Modes
Old 11-03-2009, 04:38 PM   #1
Exosphere3D
Exosphere3D's Avatar
Flight 1549 Hudson River, 3D Reconstruction
while this is definitely not photo-real work, i wanted to share my lightwave project because it shows another application of the software: engineering-based animation. all rendering is done in LW9.6, compositing of layers in adobe premiere.
project homepage
youtube vid
youtube radar animation
here are a few of the highlights regarding equipment, files, etc:
hardware: 8 core xeon 5410, 32Gb RAM
total render time: 175+ hrs for the 6 minute animation
memory used while rendering: 21 Gb RAM (obviously using LW64 bit)
polygons: 15 million
largest single texture image: 20,523 x 15,242 pixels (312 megapixels)
size of LW working content folder: 10 Gb
geographic extent of terrain/textures: 100,000 km^2 (230 x 170 miles)
detailed area with vegetation and buildings: 800 km^2 (21 x 15 miles)
my overall technique is to create what i call "sub-scenes" to make working easier. for example, i have the following scenes (which i may refer to as a "rig", even though it's not what lightwave calls a "rig"):
atmosphere and sky
building rig
datum references
fire, smoke, splash
flightpath reconstruction
radar data
rigged aircraft with dfdr
sticky surface rig
terrain rig
vegetation rig
master scene
by working in sub-scenes, i have a quicker workflow and it's easier to load and unload. i create a master scene when all the foundation work is completed and use the "load items from scene" technique to bring everything in. needless to say, i wish there was a way to work with scene files by reference and wouldn't be surprised if there is a plugin for it that i maybe don't know about.
my master scene takes about 10 minutes to load, mostly becuase of the buildings and trees. without global illumination turned on, i can render a full HD 1080 frame in about 1 minute. with radiosity (GI), the time starts out at 1.5 minutes and cranks up to 6 minutes once the radiosity cache builds up. i did not render the entire movie with radiosity, only portions of it. my machine is fairly fast but by no means a supercomputer.
most views are rendered at 1280x720 and upscaled in the final compositing. i rendered everything at 15fps and composited at 30fps in adobe premiere, allowing it to handle frame blending. this was the best compromise of quality and speed. some views are rendered with motion blur which helps a bit and by far the most popular effect is the depth of field. luckily it give a nice look to the movie, because it does cost about 15% on render times for this particular animation.
i used skytracer2 for the atmosphere, hypervoxel sprites for the fire and smoke effect (very quick render times compared to volume HVs!) and i utilize the built-in ground fog plugin to create a distance effect. i was using a 32bit image file for terrain displacement, but that was taking 30 seconds per frame to freeze the mesh, so i *baked* a polygonal terrain object and sacraficed some accuracy in exchange for speed. i used pawel olas' random cloner to create distributions for my vegetation, as well as some other tricks, but that is the only purchased plugin i used.
all of the control surfaces are bone-animated and really don't show up in the camera views selected. they are all driven with data from the flight data recorder; the ailerons, elevators, horizontal stabilizer, slats, flaps, spoilers and rudder each move according to the actual accident data. one problem with using bones for animating the control surfaces is that you can't use mesh deformations and, for example, make the wings flex at the same time. however my focus here wasn't on details quite that small so i sacrificed in the area of rigging and did what was relatively quick and painless.
the radar data movie is my favorite animation but is definitely less spectacular to the casual observer. i used hypervoxels to display temporal data from two radar facilites. i utilized equations to create numeric displays that show the altitude of each aircraft. it's challenging to rig the textures and objects to render in the appropriate manner. with the radar data animation, i rendered out tiff's with an alpha channel so that i could overlay the data onto a basemap. the quicktime movie with alpha for that animation is 21 gigabytes! it is really cool to watch it in 10x timelapse, because you can see the flock of birds intersect with 1549, then you can see them disperse, re-form and then continue on their way.
you can see the birds in the animation, at time ~2027:11. i made some very simplified objects of the appropriate size, but they are definitely not geese if you looked at them close. for all the work it took to figure out exactly where they were and at what time, they only flash across the screen for a few frames.
lightwave really helps bring thigs together and serves as a great visualization tool. i am always amazed at how much you can see when you take a bunch of "random" information and put it together in space and time.
Click image for larger version
ID:	78979   Click image for larger version
ID:	78980   Click image for larger version
ID:	78981   Click image for larger version
ID:	78982   Click image for larger version
Exosphere3D is offline   Reply With Quote
Old 11-03-2009, 06:27 PM   #2
H_Molla
H_Molla's Avatar
well done...
__________________
Hesham El Molla
Proudly " HARDCORE Member "
Powered by " NEWTEK "
H_Molla is offline   Reply With Quote
Old 11-03-2009, 06:53 PM   #3
CGI Addict
CGI Addict's Avatar
Absolutely incredible work Exo and thanks for the info.
__________________
Michael Borjon
www.pixelcollab.com
CGI Addict is offline   Reply With Quote
Old 11-04-2009, 09:35 AM   #4
JeffrySG
Pixel and Poly Pusher
JeffrySG's Avatar
Quote:
Thanks for sharing!
JeffrySG is offline   Reply With Quote
Old 11-04-2009, 12:49 PM   #5
ivanze
ivanze's Avatar
Excellent work!!
ivanze is offline   Reply With Quote
Old 11-04-2009, 01:34 PM   #6
mangray
Bowdown
Super Work
nice day
mangray
mangray is offline   Reply With Quote
Old 11-04-2009, 02:20 PM   #7
flashover
The guru of the marketing
flashover's Avatar
Ehi very cool
__________________
Lightwave is my Kung Fu!
flashover is offline   Reply With Quote
Old 11-04-2009, 04:52 PM   #8
MooseDog
Dreamer
MooseDog's Avatar
amazing!! very cool "rig"
__________________
We are pirates, we are artists...
Blog
MooseDog is offline   Reply With Quote
Old 11-04-2009, 07:48 PM   #9
sublimationman
sublimationman's Avatar
It's been said already but... Excellent!!
sublimationman is offline   Reply With Quote
Old 11-08-2009, 05:01 AM   #10
opm
out of range
WOOOOW
Really good job and hard work
opm is offline   Reply With Quote
Old 11-09-2009, 04:04 PM   #11
Hieron
"It should be called "engine suck", the birds aren't striking.."
- Eddie Izzard
Couldn't resist
Nice work, great looks on the ground detail and sky too.
Hieron is offline   Reply With Quote
Old 11-09-2009, 10:02 PM   #12
robster
Lost in 3D Space
robster's Avatar
Cool reenactment and great work on an event that happened within a few miles from where I live.
__________________
"Think of the solution, not the problem." - Terry Goodkind
robster is offline   Reply With Quote
Old 04-06-2010, 09:59 AM   #13
Exosphere3D
i have recently uploaded a couple videos that show (in limited detail), the wireframes, textures, lighting effects, etc. that comprised the final animation. i thought the LW community would enjoy some alternative looks at this project.
this first vid shows some close-ups of the aircraft controls in motion and the texturing. don't be fooled by the title of the video, it's definitely not a tutorial on rigging, it just shows the end-result of making things move:
http://www.youtube.com/watch?v=nkwsAGaYlrU
this video shows the wireframes, texturing and lighting effects at various points along the timeline of the original animaiton. i've always enjoyed seeing the layer breakdown of how things become finished.
http://www.youtube.com/watch?v=od7SujOFuuI
i hope these prove to be insightful for other artists!
Old 04-06-2010, 10:17 AM   #14
Sampei
non planar triangle
Sampei's Avatar
very impressive stuff, thanks for sharing
Sampei is offline   Reply With Quote
Old 04-15-2010, 03:25 PM   #15
Lewis
Member # 777
Lewis's Avatar
That's very good usage of LW, great work man.
__________________
www.lewis.tomsoft.hr
H WS-i7@4GHz/12GB/Win7 64/Nv260
H RS Q6600@3.4Ghz/8GB/Xp64/Nv8800
W WS-Q6600@3.1Ghz/8GB/Xp64/Nv8800
W RS 1-Q6600@3.3Ghz/8GB/Xp64/Nv9800
W RS 2-i7@3.6Ghz/12GB/Xp64/Nv240
Lewis is offline   Reply With Quote
Reply
Tags
aircraft, city, engineering, flight 1549, prn, terrain
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Powered by vBulletin® Version 3.8.2
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Copyright 2000-2007, NewTek
