Old 12-03-2007, 07:55 PM   #1
WilliamVaughan
LightWave Zombie
WilliamVaughan's Avatar
Hours of Free LightWave Training (24 Hours+)
***Interactive List****
ftp://ftp.newtek.com/multimedia/movi...eTraining.html
Newest Videos:
Please note: New videos will be listed here and once added to the list below by our good buddy Chuck, will be removed. Check here for the latest videos and then find them by category below.
Introduction to Load Items From Scene:
Click Here to view
Introduction to the Dope Sheet:
Click Here to view
Introduction to the Sewing Tool:
Click Here to view
Introduction to FX HardLink:
Click Here to view
UV unwrapping with Dynamics:
Click Here to view
Using Light Incidence as an input parameter for a gradient:
Click Here to view
Modeling and animating a basketball net:
Click Here to view
Introduction to the Surfaces Tab in the Scene Editor:
Click Here to view
Introduction to the Items Tab in the Scene Editor:
Click Here to view
Introduction to Motion Blur:
Click Here to view
Introduction to the Limited Region and Mask options:
Click Here to view
How to create custom shadows or have surfaces not cast shadows at all:
Click Here to view
Introduction to the Standard Material Node:
Click Here to view
Introduction to the BRDF shader:
Click Here to view
Introduction to the Surface Mixer shader:
Click Here to view
Introduction to the Weave shader:
Click Here to view
Introduction to the Occlusion shaders in the Node Editor:
Click Here to view
Introduction to FX MetaLink Morph:
Click Here to view
Introduction to Dynamics Effect and Record Motion:
Click Here to view
Creating shell casings ejecting from a gun:
Click Here to view
Introduction to Bone Dynamics:
Click Here to view
Introduction to Cookies and Gobos:
Click Here to view
Introduction to Volumetric Lighting:
Click Here to view
Introduction to the Text tool:
Click Here to view
Maintaining proportions when creating a UV map:
Click Here to view
Introduction to Bone Split, Bone Connect, Bone Fuse and UnParent Bone:
Click Here to view
Introduction to Sticky and Sticky Surface:
Click Here to view
Creating a Slug using Hypervoxels:
Click Here to view
Introduction to Make UVs:
Click Here to view
Creating a UV map for a Head:
Click Here to view
Customizing Modeler's Workspace Viewports:
Click Here to view
WilliamVaughan is offline
Old 12-15-2007, 08:54 PM   #2
Chuck
NewTek 3D Division
Chuck's Avatar
LightWave Training Videos - By Category
Please note: * - Indicates a video listed in multiple categories.
Modeling
Modeler - General
Introduction to the Grid and Grid Square Size:*
Click Here to view
Introduction to Action Center Control:
Click Here to view
Taking a closer look at Input Fields:*
Click Here to view
- Using LightWave's input fields to calculate and convert units of measure.
Introduction to Toggle Backdrop On/Off:
Click Here to view
Note: The Toggle Backdrop video also shows how to add this feature to the interface and setup a shortcut key to help save time when using it.
Click Here to view
Introduction to the Interactive Paste Tool:
Click Here to view
Introduction to Sketch Color:
Click Here to view
Introduction to Color Selection:*
Click Here to view
Note: Includes the LightWave Color Picker. Works the same way in Modeler and Layout, although Layout is the only application shown.
Modeling Tools
Create Tab
Click Here to view
Introduction to the Platonic Solid Tool:
Click Here to view
Introduction to the Gemstone Tool:
Click Here to view
Modify Tab
Introduction to Translate Plus:
Click Here to view
Introduction to Move Plus:
Click Here to view
Introduction to the Rove Tool:
Click Here to view
Introduction to the Rotate About Normal Tool:
Click Here to view
Introduction to the Rotate to Object Tool:
Click Here to view
Introduction to the Rotate to Ground Tool:
Click Here to view
Introduction to the Bend Tool:
Click Here to view
Introduction to Segment Scale:
Click Here to view
- Segment Scale introduction and examples
- Location of Tool Color preferences setting
Introduction to the Drag and Snap Drag Tools:
Click Here to view
Introduction to the Center, Center 1D and Center Sel 1D functions :
Click Here to view
Introduction to Center Scale and Center Stretch:
Click Here to view
Introduction to the Scale and Rotate Morph Tools:
Click Here to view
Multiply Tab
Introduction to the Bevel Tool:
Click Here to view
Introduction to Magic Bevel:
Click Here to view
Introduction to the Rail Bevel Tool:
Click Here to view
Introduction to the Lathe Tool:
Click Here to view
Introduction to the Band Saw and Band Saw Pro Tools:
Click Here to view
Introduction to the Router Tool:
Click Here to view
Introduction to the Create Skin tool:
Click Here to view
Introduction to the Morph Polygons Tool:
Click Here to view
Introduction to the Motion Path Extrude Tool:
Click Here to view
Introduction to the Julienne tool:
Click Here to view
Introduction to the Make Pole tool:
Click Here to view
Introduction to the Helix tool:
Click Here to view
Introduction to the Sea Shell tool:
Click Here to view
Introduction to the Triple Tools: (Triple, Fast Triple Fan and Fast Triple Traverse)
Click Here to view
Construct Tab
Introduction to the Reduce Points and Polygons commands:
Click Here to view
Introduction to the Collapse Polygons command:
Click Here to view
Booleans vs Speed Booleans:
Click Here to view
Introduction to the Drill Tools: Drill & Solid Drill:
Click Here to view
Introduction to Remove Polygons and Remove Vertices from Polygons Commands:
Click Here to view
Introduction to Band Glue:
Click Here to view
Detail Tab
Introduction to the Weld, Unweld and Weld Average commands:
Click Here to view
Introduction to the Set Value command:
Click Here to view
Note: Not to be confused with the Set Map Value command
Introduction to the Point Center and Find Center Commands:
Click Here to view
Introduction to the Angle Tool:
Click Here to view
Introduction to the Measure Tool:
Click Here to view
Introduction to the Absolute Measure tool:
Click Here to view
Introduction to Fix 3-5:
Click Here to view
Introduction to Align Polygons:
Click Here to view
Introduction to Add Edges:
Click Here to view
Map Tab
Introduction to Set Map Value:
Click Here to view
Introduction to the UV Spider command:
Click Here to view
Click Here to view
Setup Tab
Introduction to the power of Powergons:*
Click Here to view
Creating a PowerGon in Modeler; Using a PowerGon in Layout.
Utilities Tab
Reserved for future videos.
View Tab
Introduction to the Hide options:
Click Here to view
Introduction to the Pivot Tool and Center Pivot Command:
Click Here to view
Hotkey-only
Introduction to the Jump Points Command:
Click Here to view
Introduction to the Rotate 90 to the Right Command:
Click Here to view
Introduction to the Center View on Cursor Command:
Click Here to view
General Modeling
Modeling a Tennis Ball:
Click Here to view
Creating seams in a football model (Multiple tools and techniques covered):
Click Here to view
Using Endomorphs in the Modeling process:
Click Here to view
Modeling a bowl of cereal with a little help from HardFX:*
Click Here to view
Randomly placing surface voxels on an object:
Click Here to view
Uses Modeler tool for adding random points, "Random Pricks", then applies Hypervoxels in Layout.
Introducing the 4 point triangle:*
Click Here to view
Adding thickness to single-sided geometry:
Click Here to view
Three quick techniques for adding thickness to single-sided geometry.
Modeling and animating a basketball net:*
Click Here to view
Hard Surface Modeling
2 Methods for creating a PaperClip:
Click Here to view
Creating a model with threads using subpatches and all quads:
Click Here to view
Be sure to check out JeffrySG's killer technique here as well:
http://www.newtek.com/forums/showthread.php?t=77441
Creating a curved metal weaved mesh:
Click Here to view
Modeling a Texas star:
Click Here to view
Solution for creating 'X' and 'T' pipe joints in SubD :
Click Here to view
Creating Cathedral Ceilings:
Click Here to view
Creating a Clothespin:
This two part video tutorial walks through the creation of an everyday clothespin while exploring various techniques and tools along the way.
Part 01:
Click Here to view
Part 02:
Click Here to view
Reference Images:
Click Here to view
Organic Modeling
Introduction to Endomorphs, Morph Mixer and Open GL Sliders:*
Click Here to view
The first portion of the video shows how to create endomorphs in a character model. The rest of the video shows how to use endomorphs for character animation in Layout.
Using curves to create skelegons with the use of Convert Skelegons:*
Click Here to view
The first portion of the video shows how to create skelegons in Modeler using spline draw; the last portion shows how to convert the skelegons to bones in Layout.
Introduction to Edit Skelegons:
Click Here to view
Creating a cartoon elbow joint:*
Click Here to view
Shows two types of geometry for joints - "Rule of 3" 3-banded, and Jonny Gordon's 2-band-with-EndoMorph; shows adding bones, flexing and shape control in Layout of the latter.
-- Check it out in action here:
-- http://www.zerogravity.com.au/gallery/3Ddig/Zula.htm
Creating an animation of a crowd of people:*
Click Here to view
Creating EndoMorphs for a simple character model, in Modeler; using the model and Morph Mixer to create a crowd in Layout.
Click Here to view
Creating a UV map for a Head:*
Click Here to view
*Indicates a video listed in multiple categories.
__________________
Chuck Baker
3D Development Mgr.
Bug Report and Feature Request Database Instructions
Dell Precision M4300
Core 2 Duo 1.99GHz
2 GB RAM
nVidia Quadro FX 360M
driver 6.14.11.119
1680 x 1050
Win XP Pro SP2
Chuck is offline
Old 01-14-2008, 03:55 PM   #3
Chuck
NewTek 3D Division
Chuck's Avatar
Surfacing/Texturing
Tools
Click Here to view
Mapping
1 Weight Map, 1 Surface = Multi-Surfaces:
Right-Click Here and Save to view
Introduction to Texture Guide:
Introduction to Color Vertex Maps:
Introduction to texturing with image maps:
Click Here to view
Using a Clip map with Shadow Maps:
Click Here to view
Using Weightmaps and Adaptive Pixel Subdivision to control the level of detail at render time:
Click Here to view
How to Apply procedural textures with a UV map:
Click Here to view
Shows methods to apply procedurals with a UV Map in both Surface Editor and Node Editor.
Click Here to view
Click Here to view
UV unwrapping with Dynamics:*
Click Here to view
Surface Editor
Introduction to the Special Buffers options in the Surface Editor:
Click Here to view
Introduction to the Halftone Shader:
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Using Light Incidence as an input parameter for a gradient:*
Click Here to view
Demonstrated in both the Surface Editor and in the Node Editor
Node Editor
Creating Texture Displacement and more in the Node Editor:
Click Here to view
Multiple Bumps on one Surface in the Node Editor:
Click Here to view
Using Multiple Weight Maps on 1 Surface:
Click Here to view
Setting up a Distance to Object Gradient in the Node Editor:
Click Here to view
Node Editor: Creating Stitches with Procedural Textures:
Click Here to view
Creating Spiderman-type suit webbing:
Click Here to view
Creating a Radar Motion Trail:
Click Here to view
Creating a glass surface using the Dielectric Material Node:
Click Here to view
Creating a 2D Cel Shade look with the Node Editor:
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
__________________
Chuck Baker
3D Development Mgr.
Core 2 Duo 1.99GHz
2 GB RAM
driver 6.14.11.119
1680 x 1050
Win XP Pro SP2
Chuck is offline
Old 01-23-2008, 03:26 PM   #4
Chuck
NewTek 3D Division
Chuck's Avatar
Layout
Click Here to view
- Using LightWave's input fields to calculate and convert units of measure. Demonstrated in Modeler, applies to Layout as well.
Click Here to view
Click Here to view
Introduction to the Use Global option:
Click Here to view
Introduction to the Schematic View:
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Animation
Animation Tools
Introduction to the Target Item option:
Click Here to view
Introduction to Serpent:
Click Here to view
Covers Lazy Points, Inertia, Serpent, Cloth FX, HardLink< MetaLink and more!
Introduction to Cyclist:
Click Here to view
Introduction to the Move Path and Path Tool:
Click Here to view
Introduction to the Effector custom object:
Click Here to view
Note: Be sure to watch the Effector video "Using Effector to displace a tube".
Introduction to the Textured Motion, Motion Modifier:
Click Here to view
Introduction to Lead the Follower Motion Modifier:
Click Here to view
Introduction to Proxy Pick:*
Click Here to view
Introduction to the Jolt Motion Modifier:*
Click Here to view
Click Here to view
General Animation
Creating a rope and pulley animation:
Kickn' it Old School!
Click Here to view
Creating a “Slinky-Style” spring animation:
This one has all kinds of goodies inside.
Click Here to view
Techniques for animating a spiral motion:
Click Here to view
Creating Multiple Pivot Points for one Object:
Click Here to view
Setting up an animation rig for window blinds:
Click Here to view
Animating carpet rolling and unrolling:
Click Here to view
Animating a Page turning:
Click Here to view
Setting up an animation of multiple pins driven by a displacement map:
Click Here to view
Now go off and do something like this: http://www.youtube.com/watch?v=V0u0AG_floQ
Using Effector to displace a tube:
Animating a shaded object converting to a wireframe object:
Click Here to view
Rigging and animating an accordion style hinge:
Click Here to view
Localized morphing of an object based on the distance of another object:
Click Here to view
Be sure to also check out the video "Localized Morphing Used on a Face Rig" under the Character Animation section.
Localized morphing of an object based on the distance of another object using Normal Displacement:
Click Here to view
Animating Cameras and Lights
Creating a hand-held camera motion:
Click Here to view
Creating a light flicker using Noisy Channel:
Click Here to view
Animating a Muzzle Flash synced to an audio file:
Click Here to view
Introduction to Sun Spot:*
Click Here to view
Click Here to view
Animating an explosion affecting Camera motion using the Jolt Motion Modifier
Vehicle Animation
Animating Tank Treads:
Click Here to view
Note: The treads animate smoothly, though the framerate of the capture software looks otherwise. Give the setup a try and you will see how well it truly works.
Animating a train or roller coaster on a curved track:
Click Here to view
Relativity: Dr. Wheel Rotator:
Click Here to view
Animating an Escalator:
Click Here to view
Character Animation
Introduction to Bones and Character Rigging:
Click Here to view
Introduction to IK: Inverse Kinematics:
Click Here to view
Introduction to the RIG format:
Click Here to view
Building a Reverse Foot Rig:
Click Here to view
Click Here to view
Animating a basic walk cycle:
Click Here to view
Note:If your new to animation and setting key frames this could be a good quick start for you.
Click Here to view
Creating an eye setup for animating eyes with ease:
Click Here to view
How to setup a cartoon oval eye for animation:
Localized morphing used on a face rig:
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Introduction to Bone Dynamics:*
Click Here to view
Introduction to FX MetaLink Morph:*
Click Here to view
Introduction to Dynamics Effect and Record Motion:*
Click Here to view
Particles
Animating a bouncing ball using a particle emitter:
Click Here to view
Creating rain splashing on the ground using particle emitters:
Click Here to view
Creating a bottle rocket type animation with particle emitters:
Click Here to view
Creating water flowing through a piping structure:
Click Here to view
Dynamics
Introduction to the Group feature for Dynamics:
Click Here to view
Using Cloth FX to Tear/Rip Material:
Click Here to view
Creating Foot prints in the ground using Cloth FX:
Click Here to view
Winding a flag around a pole using Soft FX and then the same thing with Cloth FX:
Click Here to view
Buttons on a Shirt that uses Cloth FX:
Click Here to view
Introduction to HardFx and Object Dissolve:
Click Here to view
Animating a hose that is connected to an object on each end:
Click Here to view
Using FXLinker to Mimic Modeler's Point Clone Plus feature in Layout:
Click Here to view
Click Here to view
Creating a flag blowing in the wind:
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
Click Here to view
__________________
Chuck Baker
3D Development Mgr.
Core 2 Duo 1.99GHz
2 GB RAM
driver 6.14.11.119
1680 x 1050
Win XP Pro SP2
Chuck is offline
Old 01-23-2008, 03:26 PM   #5
Chuck
NewTek 3D Division
Chuck's Avatar
Lighting
How to set up the Spinning Light Trick and an introduction to Luxigons:
Click Here to view
The Spinning Light Trick was first developed by Dave Jerrard if I remember correctly. That guy has created more cool techniques then anyone I know!
Enjoy the video!
Introduction to Negative Lights:
Click Here to view
Click Here to view
Introduction to Light Exclusion:
Click Here to view
Click Here to view
Click Here to view
Effects
Compositing
Introduction to Compositing inside of LightWave:
Click Here to view
Introduction to working with Foreground Images in the Compositing tab:
Click Here to view
HyperVoxels
Click Here to view
Click Here to view
Click Here to view
Rendering
Introduction to Render Buffer View:
Click Here to view
Introduction to Render Buffer Export:
Click Here to view
Manually creating a depth pass:
Click Here to view
Introduction to the Photoshop PSD Export Image Filter:
Click Here to view
Introduction to the Image Control Panel for the Image Viewer:
Click Here to view
Click Here to view
Click Here to view
Creating trussing and framework with ease:
Kickn' it New School!
Click Here to view
Click Here to view
Uses render settings similar to the Creating Trussing and Framework video to render two-point polys with thickness and shading.
__________________
Chuck Baker
3D Development Mgr.
Core 2 Duo 1.99GHz
2 GB RAM
driver 6.14.11.119
1680 x 1050
Win XP Pro SP2
Chuck is offline
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
