Old 01-26-2009, 10:00 AM   #1
Graphx
Clouds
How do you setup a scene to show that you were flying through clouds. I think you should be able to do something like that with hypervoxels but I don't know how to set up right.
Graphx is offline   Reply With Quote
Old 01-26-2009, 03:47 PM   #2
stevecullum
Lightwave junkie
stevecullum's Avatar
Just add an HV volumetric to a couple of nulls and then adjust the setting to be more cloud like. Then pass the camera through them.
stevecullum is offline   Reply With Quote
Old 01-26-2009, 04:49 PM   #3
3DGFXStudios
Space Monkey
3DGFXStudios's Avatar
You can also use sprites and use them on points. That renders faster...
__________________
3DGFXStudios is offline   Reply With Quote
Old 01-28-2009, 03:18 PM   #4
Iaian7
VFX Generalist
Iaian7's Avatar
Another option is to use multi-layered geometry with procedural textures driving transparency... oldest trick in the book, but it can work, and work well. Combining that (20+ layers and a lot of nodal texturing) with a little After Effects, and I've been able to create volumetric-like cloud flythroughs with much better results than hypervoxels (which I've never gotten to look good). I'd post a link to my process, but that tutorial was never really finished... hmm... if I get time this week, maybe I'll try to whip it together.
__________________
Iaian7 / John Einselen | reels | galleries | photos | blog
2.8Ghz 2x4 Xeon Mac Pro, 10Gb RAM, Nvidia 8800GT, OS X 10.6.2
2.8Ghz Core 2 Duo MacBook Pro 15.4", 4Gb RAM, Nvidia 9600M, OS X 10.6.2
Iaian7 is offline   Reply With Quote
Old 01-29-2009, 01:26 AM   #5
nikfaulkner
mucho mojo
nikfaulkner's Avatar
that sounds very interesting iaian7.
i look forward to it
__________________
yeah alright.... we won a BAFTA http://littleloud.com/work/bsr/
nikfaulkner is offline   Reply With Quote
Old 01-30-2009, 12:27 PM   #6
toeknee
toeknee's Avatar
Hey Graphx
I agree with the idea of points and Hypervoxels but what I did for a resent project that worked great was to use the plugin Dynamite. I just needed the free plugin and I would use it to make images of cloulds. Then I expoted the Image in an image format that used an alpha channel. I then made some polygons and maped them them. The cool thing about this is that Dynamit is great for making clouldes and when you map them to a polygon you can animate the polygon and have a very reallistinc looking clould scene. if I find the base scene for dynamite I will post it later. Good luck.
__________________
The LW Beast From the East
toeknee is offline   Reply With Quote
Old 01-30-2009, 12:55 PM   #7
stevecullum
Lightwave junkie
You can always bake the hypervoxels to make them speedy to render
Old 01-30-2009, 02:17 PM   #8
3djock
3djock's Avatar
Quote:
Sounds interesting just what I'am looking for also.
3djock is offline   Reply With Quote
Old 02-06-2009, 07:12 AM   #9
JBT27
What do I know?
JBT27's Avatar
I know it's an infernal cheek.....but if you can do that tut, or a bit of it, I'd be very grateful. I get the gist of what it must require to do it that way, but if you've got results comparable, or actually better, than HVs, I'm all ears
Julian.
__________________
http://www.take27.co.uk
Intel Core 2 Quad Q9550 @ 2.83Ghz
8Gb RAM
GeForce 9800 GT with 197.45 Driver
Win XP Pro x64 SP2
LW 9.6
JBT27 is offline   Reply With Quote
Old 02-06-2009, 01:46 PM   #10
Iaian7
VFX Generalist
Iaian7's Avatar
Haha, no, it's fine! I'm sorry it's taking so long to get the tutorial done... I'm not very good at writing them, and life is pretty tumultuous right now. Till I get something more posted tonight, I'm attaching an example from a project I did last year.
Click image for larger version
__________________
Old 02-06-2009, 02:16 PM   #11
JBT27
What do I know?
JBT27's Avatar
Good grief, that is superb, and just the kind of thing I need to get me out of the HV hell I've been wallowing in all day
Seriously, some pointers would be great, even hints if not a full tut.....
Really impressed by those clouds!
Julian.
__________________
8Gb RAM
Win XP Pro x64 SP2
LW 9.6
Old 02-06-2009, 05:58 PM   #12
prometheus
Those clouds are impressive Iaian7!
so those are only geometry and procedurals on transparency that is?
But how would it stand up against objects inside the cloud volume and fly throughs?
It would be nice to see an animated sequence if you have?
Michael
__________________
dohh!
prometheus is online now   Reply With Quote
Old 02-06-2009, 06:41 PM   #13
prometheus
here´s a little sample ..of hypervoxels clouds a particle emitter and a simple turbulence hypertexture, shading set to good quality, no volumetric
shadows or texture shadows..
illumination model beer(should use rayleigh for more realistic results)
lumunosity has a y-distance to particle gradient in additive mode over
another gradient set to local density.
on the thickness channel there´s also a gradient set to distance to object and emitter as choosen object.
one of the images has 70 particles and the other 100 particles.
of course we can always use sprayed points aswell.
But setting this up goes very fast...the rendertime takes a little longer thou.
then there´s a whole other story of getting nice background air and air properties to interact with the hypervoxels, not so easy to do..so I settled for a simple blue color
otherwise..ogo taiki or ozone could handle that nicely.
Michael
ID:	69449   Click image for larger version
__________________
dohh!
Old 02-07-2009, 12:24 AM   #14
nikfaulkner
mucho mojo
wow Iaian7, they look great
cant wait for some more info (or a little demo scene if its easier than writing a tutorial )
hopefully see more soon
n.
__________________
Old 02-07-2009, 03:29 AM   #15
JBT27
What do I know?
JBT27's Avatar
Michael
Those are nice!
Bit of a debate really which is best, though I suspect both have their place.
I've been getting some serious popping with my thin-cloud flythrough, which I suspect is the old problem of the camera being too close to the HVs - desperately searching around to find detail on that, as I cannot finish this shot until I do.....hence wanting other ways to achieve this.
How you fly through HV clouds without getting too close to the HVs I haven't figured yet
I tried some random geometry with transparency driven by procedurals - getting potential results with alot of spherical objects, but still not losing the ghosted appearance of the original objects.
Julian.
__________________
8Gb RAM
Win XP Pro x64 SP2
LW 9.6
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Copyright 2000-2007, NewTek
